Putopis - Grčka - Makedonija - Albanija - Crna Gora - 2013
Zaključana tema
Sanja Obrenovac
Postovi: 32
Pridružio se: 22 Avg 2013 16:17
Post od Sanja Obrenovac »
STARTOVALI SMO IZ OBRENOVCA 02.08.2013 POSADA VESELA MUZ,CETVORO DECE I JA.NA GRANICI SA MAKEDONIJOM GUZVA A NA PRVOJ PUTARINI CEKANJE OD SAT VREMENA.KROZ MAKEDONIJU JE PUT SOLIDAN PUNO JE NEOSVETLJENIH PARKINGA PUTARINE SE PLACAJU U DENARIMA.U GRCKU SMO USLI NA EVZONI A PO PREPORUCI PRIJATELJA OTISLI SMO U KAMP POSEJDON U MESTU SKOTINA TO JE 738KM OD OBRENOVCA.DNEVNI ZAKUP ZA NAS 6 I KAMPERA SA STRUJOM I INTERNETOM POSLE CENKANJA JE 30E.ZBOG NEISKUSTVA,BROJNOSTI I NEOBAVESTENOSTI TU SMO OSTALI 9 DANA UMESTO DA IDEMO 2-3 DANA PLAZE A1 KAMP,SAD ZNAMO ZA UBUDUCE.STO SE KAMPA TICE USLOVI SU DOBRI VRUCA VODA 24H DNEVNO, NA SAMOJ PESKOVITOJ JE PLAZI , VODA CISTA I TOPLA,BEZ IKAKVIH CIRKUSA NA VODI.KUCNI RED SE STROGO POSTUJE.OVOM PRILIKOM POZDRAVLJAMO PEDJU,RADU I TEODORU IZ NISA.NE TREBA PROPUSTITI PRILIKU DA SE ISPRED KAMPA POCASTITE NAJLEPSOM PIZOM PECENOM NA DRVA.IZ GRCKE SMO SE PREKO EVZONIJA UPUTILI KA OHRIDU PREKO NEGOTINO,KAVADARACA,PRILEPA I BITOLE.PUT JE PRILICNO LOS,ASFALT JE ISECEN,KRIVINE OSTRE,SA VELIKIM NAGIBIMA.KRAJOLIK JE LEP,PROSARAN VINOGRADIMA.POLJIMA SUNCOKRETA I DUVANA.OHRID JE NA 378KM OD POSEJDONA.SMESTILI SMO SE NA SAMU PLAZU KOJAJE DOBRO UREDJENA.VODA JE CISTA ALI NESTO HLADNIJA ZA KUPANJE.VECE U OHRIDU JE ZA PAMCENJE,STARI GRAD,MODERNE PRODAVNICE,PO ULICAMA I TRGOVIMA MNOSTVO KULTURNIH MANIFESTACIJA.ATMOSFEROM I MIRISIMA MALO PODSECA NA PRIMORSKE GRADOVE HRVATSKOG PRIMORJA IZ PREDRETNIH DANA.CENE SU PRISTOJNE I NARAVNO SVE SE PLACA U DENARIMAPREPORULI BISMO SVIMA KOJE PUT NANESE BLIZU OHRIDA DA NE PROPUSTE PRILIKU DA GA POSETE BAR NA 1 DAN.POSLE JUTARNJE KAFE NA PLAZI U DOMACOJ REZIJI,KRENUKI SMO PU ALBANIJEPREKO STRUGA DOSLI SMO NA GRANICNI PRELAZ CALFASAN.NIJE BILO NIKAKVIH PROBLEMA.PUT JE DOBAR,PREDEO JOS BOLJIJEDINO SE NA OBRONCIMA PONEGDE JOS UVEK VIDE BETOSKI BUNKERI IZ TESKIH VREMENA DA JOS UVEK STOJE.PROLAZIMO KROZ MANJA MESTA,IMA DOSTA LJUDI NA ULICAMA,VOZE SE DOBRA KOLA ALI IMA I ZAPREGA SA KONJIMA ILI MAGARCIMA.ONI KOJI PREPOZNAJU REGISTRACIJU MASU I OSMEHOM PRATE NAS PROLAZAK,SVE VREME SLUSALI SMO NASU MUZIKU I NISMO IMALI NIKAKVIH NEPRIJATNOSTI.USPUT SMO STALI DA KUPIMO SMOKVE NA ZALOST JEZICI IM NISU JACA STRANA A I U NOVAC SE RAZUMEJU SAMO AKO JE NJIHOV LEKE TAKO DA MOZE DA SE DESI DA ISTU KOLICINU VOCA DOBIJETE I ZA 1 I ZA 2 EVRA.PROSLI SMO KROZ EL BASAN TREBA BITI OPREZAN JER VOZE BEZ POSTOVANJA SAOBRACAJNIH PROPISA.ODATLE IDEMO KA DURASU TJ. DRACU I STROGO SE DRZIMO OGRANICENJA JER POLICIJE IMA I PREVISE MADA NAS NISU NI JEDNOM ZAUSTAVILI.DO DRACA IMA JEDNA DEONICA STAROG,LOSEG PUTA DUZINE OKO 2.5KM KOJI JE UZAN,PUN RUPA,PROMETAN I TESKO JE ZA MIMOILAZENJE SA VECIM VOZILIMA.PRE ULASKA U GRAD NA BANKINAMA AUTO PUTA SU DRVRNR MERDEVINE KOJE MESTANI KORISTE ZA PRELAZAK NA DRUGU STRANU.NA ULASKU U GRAD SU HOTELI KOJI PODSECAJU NA BLOKOVE NA N.BGD.TU JE BIO ZASTOJ KOJI JE NASTAO KADA SU TRAKE U OBA PRAVCA ZAKRCILI VOZILA SA AUTO PUTA I TRAJAO JE PREKO 45MIN ZA NEKIH 200M.NASTAVILI SMO KA GRADU LEZE I SKADRU.TU IMA KAMPOVA A KOD LEZEA SU DVA DOBRA KAMPA KOJA SU NA SAMOJ OBALI MORA.I AKO SU CENE PRISTUPACNE A USLOVI DOBRI NA INSISTIRANJE DECE OD KOJIH DVOJE NISU NASA IPAK SMO ODUSTALI OD IDEJE DA TU PRESPAVAMO.STIGLI SMO NA SOKOBIN,PRELAZ SA CG KOJI JE 293KM OD OHRIDA,CEKALI SMO NEKIH 45MIN ZA TO VREME SU NAS OPSEDALI ZENE SA DECOM DA IM DAMO NOVACILI HRANU,JAKO SU UPORNI I NAVALENTNI ALI ODUSTAJU POSLE NEKOG VREMENA AKO IH IGNORISETE.U CG PUT JE SOLIDAN ALI NIKAKO NA PRVOJ RASKRSNICI NE SKRECITE ZA BAR VEC IDITE KA ULCINJU JER JE OVO PRVO TKZ.KOZIJA STAZA TJ OBILAZNICA PREKO BRDA SVE DO BARA A PUT JE NAJBLAZE RECENO UZAS.U UTJESI GDE SU PRILICNO DOBRI KAMPOVI NIJE BILO MESTA PA SMO OTISLI NA JAZ.AZ EVROPSKU CENU TOTALNI PROMASAJ NISTA NE VALJA SEM PLAZE A ONDA SMO OTISLI U BECICE U KAMP AVALA.SOLIDAN PROSTOR,PRISTOJNO UREDJEN CAR MU DAJU STARA STABLA MASLINA.PUT DO PLAZE JE GROZAN PROLAZI SE ISPOD PUTA KROZ NEUREDJEN I PRLJAV PODVOZNJAK.GLAVNI JEZIK JE SVUDA RUSKI.NA PLAZI-VASAR,NEMA MESTA ZA PESKIRE JER SU SVUDA POLUPRAZNE LEZALJKE KOJE KOSTAJU OD 10 DO 20E.VODA JE BILA NEVEROVATNO HLADNA A I NE BAS CISTA.SA SVIH STANA VREBAJU ATRAKCIJE NA VODI GLISERI VUKU GUMENE FOTELJE GDE SE NEKI SILNO IZLOMISE DA NE ISPADNU,DRUGI SA SKUTERIMA IZDIZU NEKE LIKOVE DA PRAVE AKROBACIJE U VAZDUHU U MEDJUVREMENU 5-6 GLISERA VUCE PADOBRANE SA DVOJE TURISTA KOJI VRISTE I IZBEZUMLJENO MASU NA SVE TO POMORSKA POLICIJA KRSTARI SVOJIM PLOVILIMA DA ZAVEDE RED.ZA SVO TO VREME PRILICNO JE VELIKA VEROVATNOCA DA CE NEKI ID BAREM SEDAM PARAGLAJDERA DA VAM SLETI PRAVO NA PESKIR I SVI PRODAJU VRUCE TEK ISPECENE KROFNE.ZBOG TIH SITNICA ILI MOZDA ZBOG JAKOG SUNCA POZELELA SAM KRAJ OVOE AVANTURE.KRENULI SMO NA CETINJE MALO SE PROSETALI PO NJEMU PA NA ZLATIBOR I ONDA KUCI,SVE U SVEMU PUNO KILOMETARA,PAR IZUZETNIH NOVIH PRIJATELJA MNOGO LEPIH PREDELA I NARAVNO NAS EXTRA KAMPER DOPRINELI SU DA OVO BUDE JEDAN NEZABORAVAN DMOR.POSTAVICU I SLIKE KAD PROVALIM KAKO SE TO RADI.
Sonja odavno niko nista nije napisao o putovanjau Crnu Goru a o Albaniji tek , dakle tekst je odlican naravno sa fotografijama bi bio potpun, imas na nasem forumu upload slika pa polako resi ces problem .
Sigurno ce biti vise pitaja i uopste diskusije o destinacijama ali ide nam duga zima .
edcgear
Postovi: 9
Pridružio se: 18 Avg 2013 08:20
Lokacija: Zrenjanin
Post od edcgear »
hvala na ovom izvestaju. :-)
posebno za albaniju, vec neko vreme se vode razne polemike medju prijateljima i porodicom vezano za ovu zemlju i njene turisticke mogucnosti, i mislim da je vreme da se pocne razmisljati u tom pravcu.
Don't panic!!
poseidon
Postovi: 92
Pridružio se: 16 Dec 2009 23:23
Lokacija: nis
Post od poseidon »
E da pojasnimo situaciju:kamp Poseidon je bio baza,kako ga je krstio Mica iz Smedereva,u kome su se nasle sledece posade:Miki 56 tj. Mica i Olja iz Smedereva,Mustang,Sprinter,Sanja Obrenovac,uz kratku posetu Dragana iz Pirota i nasa malenkost Poseidon.Svi naravno sa porodicama.Druzenje je bilo prelepo,slike slede od svih nas,a o detaljima na prvom zajednickom skupu.Bilo je svega,pecanja na reci Pinios posle koga je bila i riblja corba,od soma,klena i mrene koju je pravila Olja,ludovanje gliserom i ringom itd.,i puno icaaa i picaaa...U nasoj blizoj okolini su se nalazile posade iz Beograda i Novog Sada koje izgleda nisu nasi clanovi i sa kojima smo ostvarili samo povrsne konktakte.
poseidon
Postovi: 92
Lokacija: nis
Post od poseidon »
Slika Slika Slika Slika Slika Slika Slika Slika
liiiman
Postovi: 536
Post od liiiman »
@sanja
Jako interesantan plan putovanja. Molim te da ilustrujes putopis sa fotografijama. Posebno je interesantno da vidimo fotografije iz Albanije.
@poseidon
Odlična baza koliko vidim!
Sanja Obrenovac
Postovi: 32
OHID 2013 RSlikaSlikaSlikaSlikaSlika
Sanja Obrenovac
Postovi: 32
ALBANIJA 2013 SlikaSlikaSlikaSlikaSlikaSlikaSlikaSlikaSlikaSlika
Sanja Obrenovac
Postovi: 32
GRCKA 2013 SlikaSlikaSlikaSlika
poseidon
Postovi: 92
Lokacija: nis
Post od poseidon »
Grcka,oktobar -zatvaranje sezone 2013 Slika Slika Slika Slika Rumunski kamperi Slika Slika Slika Slika
Kako je pusto i tužno. Pre dva meseca ova plaža je izgledala ovako:
Ali, bez obzira na sve, vidim da je Peđa iskoristio zadnje zrake sunca (a i pivo) za kupanje ove godine.
To je realnost kod "morskih" mesta. Leti guzva da ne mozeš da veruješ, a zimi pustara kao u avetinjskom gradu. Razlike su baš drastične.
što se tiče piva, vidi se da se čovek spakovao. Od alata ostavio samo ono što zatreba za ne daj bože na putu.
Pedja i kamper i bajker, a gde je švajcarac?
Danas ćemo prodiskutovati na tu temu.
Zaključana tema
